Welcome to beszeljukmac.com
Better Employees Avoid these Top Five Office Blunders
Being a good employee can go a long way when it comes to the workplace and job advancement. When you are working in an office there are certain unspoken rules that you will want to follow.
One of the biggest mistakes that one can make when they are working in an office is having romantic relationships with co-workers or their boss. This completely colors the work situation and can cause major problems in the workplace. Although office romances are common, they typically bring about some friction between the couple or the couple and others. The remedy for office romance issues is that usually one or both members of the romance leave the job.
Being dishonest is an office blunder that can land you in the unemployment office. Stealing from your job, lying about reports being done and trying to cause conflict by lying to one co-worker about another are all very silly mistakes that employees make. It is not acceptable to borrow money from the float, even if you are intending to pay it back. Pretending like you have completed your work when it is only half done is not wise. Gossiping and stirring up rumors is also not a good idea. All of these things can make you the bosses’ number one most wanted to fire employee.
Not following the dress code is another easy to remedy problem that many employees make. The reason why this is such a big deal is because it says that you do not care about your position enough to wear the right clothing. It also can land your boss in hot water if the director or head supervisor comes into the department. Not only will you be reprimanded for not having on proper uniform, your boss will be singled out for not making you comply with uniform standards. The too can make you very unpopular with the boss.
Saying incredibly inappropriate things is also a blunder that can easily be avoided. Jokes and comments about the way that people look in their clothing can border on the line of harassment. In fact, just about anything can be proven to be harassment by a good lawyer. That is why it is best to keep jokes and opinions about others to you and you only. You could lose your job and find yourself in a lawsuit otherwise.
The number one blunder than employees make on the job is having a bad attitude. People that are very negative bring down a crowd, not just themselves. That means that when the time comes to make cuts, the bad attitude person is the likely candidate. Removing a negative person from the workplace can bring up the morale of everyone else. Even very effective employees with bad attitude are often terminated simply because they bring down the mood and productivity of others. Be thankful that you have a job and keep a positive frame of mind. If you are not happy with your job, search for another one.
In addition to these five blunders that better employees avoid, there are a few obvious ones. Being tardy is perhaps one of the most prevalent and easy to prevent blunders employees make. Being tardy on a regular basis is not acceptable. There is no reason to continuously be tardy for work. If you are getting stuck in traffic, leave earlier or take a different route.
Being a good employee can take you a long way at work and in your personal life. It feels good to know that you are an effective person be it at work or elsewhere. Be kind to co-workers and go through your days with a positive mindset. With these tools in place you will be able to avoid blunders more effectively.
Web Hosting - Why Backups Are Essential One thing most web site owners have little time for is... anything! Anything other than focusing on their site content and the business or service it supports and the information it provides, that is. That means that administration often suffers, as it frequently must. There's only so much time in the day. But the one thing that you should never let slide are backups. They are like insurance. You rarely need it (you hope), but when you do you need it very badly. Performing regular backups - and testing them - doesn't have to be a nightmare. A little bit of forethought and effort and they can be automated to a high degree. And, they should be tested from time to time. Even when a backup appears to have gone without a hitch, the only way to know whether it's of any value is to attempt to restore the information. If it can't be restored, the backup is worthless. Even when the web hosting company provides the service, there is still some planning involved for the site owner. Hosting companies often rely on one or both of two methods. They backup everything (called a full backup), then backup anything which has changed since the last full backup (called an incremental backup). Of special interest are any configuration files that have been tailored. If you've modified the default installation of a software package, you want to be able to recapture or reproduce those changes without starting from scratch. Network configuration files, modifications to basic HTML files, CSS style sheets and others fall into the same category. If you have XML files, databases, spreadsheets or other files that carry product or subscriber information - about items purchased, for example, or people who signed up for a newsletter - those should get special attention, too. That's the lifeblood of your business or service. Lose them and you must start over. That can break your site permanently. It should go without saying that all HTML and related web site files that comprise visible pages should be backed up regularly. It isn't necessary to record every trivial change, but you can tailor backup software to exclude files or folders. Usually they're so small it isn't worth the trouble. But in some cases those small changes can add up in scenarios where there are many thousands of them. Here again, the backups are worthless if they can't be used. Even if the hosting company charges for doing so, it's worthwhile to test once or twice a year at least to ensure the data can be restored. That's especially true of database backups, which often involve special software and routines. Database files have a special structure and the information is related in certain ways that require backups be done differently. Developing a backup strategy can be straightforward. Start simply and review your plan from time to time, modifying it as your site changes and grows. But don't neglect the subject entirely. The day will come when a hard drive fails, or you get hacked or attacked by a virus, or you accidentally delete something important. When that day comes, the few minutes or hours you spent developing and executing a backup plan will have saved you days or weeks of effort. Got an Offer? How to Evaluate the Company to Ensure It’s the Right Move Being offered a new job is always a great feeling. No matter what type of job it is, the fact that the employer wants you is very satisfying. The inclination to put in your two-week notice and start packing up your desk can be exhilarating. However, be sure that you know what you are getting into before you plunge into a new job. The terms of a job offer should be written out in black and white, literally. Whenever a company offers a job to someone, there should be literature about the position to read. When the offer is made, be sure to spend some time reading over the literature and finding out exactly what the terms and conditions of the job are. Salary, benefits and the terms of employment should all be very clear before you accept the offer. Be sure that you read the fine print. This is especially true from sales jobs. That advertised rate of pay might be what you make with commission. Without the commission you may not have a salary at all. This could be a major issue if your sales do not go well. Salary is one of the most important things to find out about before you take a job. Make sure that what they are offering as base pay is enough for you to live comfortably on. Bonuses can sound really great when employers discuss them with you. However, what you have to do to earn the bonuses may be very difficult. Thus making the bonuses obsolete the majority of the time. Restaurant management is a career path where many times your bonuses are based on the success of your particular restaurant. Not you yourself. That means that when the restaurant is not doing well, there will be no bonuses. The hours you will be working is another issue you will want to tackle before you take the job. Find out exactly what you are expected to work. This could be tricky with salaried positions. Find out what the average amount of hours is that employees spend on the job. Will there be travel? Many jobs post this in their advertisements but others are not so forthcoming with this information. Living out of a suitcase can be ideal for some but if you are not looking forward to having a relationship with your spouse strictly through cell phones and e-mails, you better inquire. If you are not open to travel be sure to find out if travel could be included in your position. The environment at the office could be hard to gauge. However, if you go to an interview and are not greeted in the lobby or see a few scowling employees, chances are, the office environment is a bit hostile. This is a major thing to consider when taking a job. Is the management hiring new personnel in order to replace the existing personnel? If they are, why does the existing personnel need to be replaced? Try to feel out the environment of the office when you are waiting for your interviews to take place. What will your job entail? Will there be times that you are expected to do things that go against your better judgment? Will you be surrounded by a corporate mentality that is concerned only with numbers? Are you going to be able to put your reservations aside and carry out the job that needs to be done? If a job offer is made immediately, you may want to be leery of this position. Try to find out about the turnover rate of this position. There may be a reason why the employer is so ready to offer you the job. |
