Welcome to beszeljukmac.com
The Importance of Written Communication (written communication) Written communication is just as important as oral communication. Of course, all communication requires a clear concise flow of ideas, and words that are easily understood by any reader or listener. Written communication is one of the most difficult forms of communication as writers are typically prone to write for themselves, instead of for their audience. It is important for readers to understand what has been written and why it has been written. Writing is very different from oral communication, because words are written they cannot be taken back. Communicating through writing is more concrete than verbal communication with more room for mistakes and misunderstandings. The slightest misunderstanding can cause chaos for many, so it is important to right as clear and concise as possible. This form of communication is defined as a clear expression of ideas in writing. The clear expression of ideas includes grammar, organization, and structure of an essay, book, article, or report. Grammar is a large part of written communication, and writers must always consider spelling, punctuation, writing style, and wording before displaying their work to the world. Proper grammar and form may have a varying importance for different writing jobs, and usually depend on the method of communication used for that job. However, it is always important to strive to use correct grammar, spelling, and punctuation. Most writers use spell check and grammar check on their computers to ensure that the grammar and spelling is suitable. Grammar is also a major factor when writing as a freelance writing and submitting work to an editor. Many editors will reject further submissions from writers who have too many grammar and spelling errors. Organization of a letter, essay, article, or book is also important factors of written communication. Communication should always have a logical organization that is easy for readers to follow. For the reader, it is much easier to read a paragraph with one common theme that relates to the entire work. Most writing requires a clear flow of ideas and proper transitions to indicate when a new idea is being presented. However, transitions are not often needed for pieces of writing that are clearly organized. Ideas should also be expressed in a manner that is easy for the reader to understand and recognize. Data in the writing should also be presented accurately to support conclusions and recommendations given by the writer. The structure is also important in a piece of writing. All writing is organized into five to seven sentence paragraphs that all relate to each other. The number of paragraphs usually depends on the work that is being written. For example, it is common for essay to contain five concise paragraphs that all relate to a common theme. Generally, essays begin with an introductory paragraph, followed by three supporting paragraphs, and ended with a concluding paragraph. The basic structure of a piece of writing is only the beginning of written communication; the words used and the organization of the work is important to the readers understanding of the work. In many cases, the style format, and content must be adjusted to the communication level of the reader. The ability to convey ideas to a certain reader are very important, and a key component of written communication. Like oral communication, written communication can be seen as an aspect of life that makes the world go round, and learning to communicate through written word has become a basic skill for most people. Communication is needed in all aspects of life, and although many people cannot write well, it is important to be able to communicate out loud and on paper.
Conducting a Self-Evaluation After Getting Fired Sometimes life is hard and when you get fired, it gets even harder. In a country where employee turnover is high and there are no laws to protect you at your work place, potentially anybody is at risk to be fired. In general, that is true, but companies usually only fire a person that has done his or her job improperly, or is not qualified for his or her job any more. Therefore after you get fired, it is time that you conduct a self-evaluation. First of all, you need to make sure you know the reason why you have been fired. Do not just assume, you know why you have been fired. Make sure that your employer tells you the exact reasons why he has fired you. A self-evaluation as to whether the employer is right and whether you might have to work on yourself can only be done after you know why the company has told you to leave. If it was tardiness and absence of work that has gotten you fired, you need to be self critical enough to see that you need to be on time and be at work every day that you are not taking a vacation day. Keeping a job means playing by the rules and these rules do include times that you have to be a t work if you want to keep the job. When your boss told you, that you are not accomplishing your work or you are not qualified for the position, think back and try to find out why he might have said that. Did you deliver your work on time? Was it correct, mostly without any problems and errors? If that is not the case, then perhaps your boss was right and maybe you were not qualified enough to do the job. It might be that you need some more training or some more classes at the university to be able to do your job right. Or maybe you have just chosen a job that is not for you. When you are conducting that self-evaluation, make sure you are not too hypercritical. If it clearly was your fault that you got fired, you need to improve yourself and the personality traits that have led to the firing. Sometimes even though your boss gave you an explanation why you have been fired, you might not agree with the reason you have gotten fired from your company. Yes, sometimes these reasons might not be right. Since this is a society where anybody can get fired, maybe you have been fired because your boss did not like you and he made up some dubious reason for firing you. This is why you have to conduct a self-evaluation to make sure if what you were told is the truth. A self-evaluation might also lead you to the conclusion that you need to choose a different profession than the one you have been in. Maybe it took to get you fired to ser you in the right direction and at some point in your future you might actually thank that boss of yours that he had fired you. Otherwise you might have never found the job that you were destined for and would have been miserable doing the job you were doing. Unhappy employees are not good for a company and some bosses are good enough to realize that. Whatever the reason is that you got fired, make sure you find the reason and check with yourself how much truth lies within that reason and do you have to change to be a better employee and be able to keep your next job.
The Slam and Other Outlets for your Poetry Needs (poetry reading) Poetry is an effective display of human life and emotion. Not only are the writer’s feelings about life revealed, the reader is also taken on a journey of meaning and feeling. Poetry is an outlet for writers and readers alike. Each new poem that is written is another chapter in the entire human experience. Since people are looking for meaning within their experiences, poetry draws fans by adding that meaning. Poetry reading can be educational and enjoyable. There are many places and forms that poetry reading can take, so if you are looking for an outlet or inlet of your own, you’ll be sure to find one that will fit your needs perfectly. A Poetry Slam A poetry slam is a gathering of poetry lovers. Each person that attends brings one or several pieces of poetry to read. The poems can be individual work or work that you have come across in your poetry reading. The point is to allow everyone to enjoy poetry that they may have never heard before. As each reader places his own interpretation within his reading, everyone can enjoy the variation in style and sound and meaning that comes out of the experience. There are probably a few poetry slams scheduled in your community already. Check the library or the local college campus for more information. If poetry slams are not already being scheduled, or if they are not frequent enough for your taste, you can start your own. All it takes is a meeting place and some flyers. You’ll probably meet all kinds of people that you enjoy being with at a poetry slam. Going to Class Another place to meet other poetry lovers is in class. If there is a college or university campus near you, join a class. Poetry classes are often scheduled in the evening because of their popularity with those who are not regular students. Poetry reading happens in a couple of different kinds of classes. You can take poetry classes that focus on poetry that has been written through history. Sometimes the classes will focus on a specific group of people or time in history. As the subjects change, you can continue to take the classes and continually come across new poetry that you have not read before. You can also take poetry classes that encourage you to write your own poetry. You will then be able to read your work as well as listen to others’ work. The great thing about poetry classes is that they are set up for discussion. You can discover more meanings in other people’s writing and develop your own with the help of other qualified students as well as your professor. The Impromptu If you are involved in any other kind of poetry reading, you will probably be well immersed in the different forms of poetry. Understanding a few different writers’ perspectives will allow you to involve poetry in your every day life. As you talk to friends and relatives about typical situations that arise, you will be able to bring meaning to many of your conversations through poetry reading. You will probably also develop your own skills of writing and so be able to express yourself effectively when it comes to all kinds of human experiences. Hopefully, at impromptu poetry readings, you’ll be able to inform your friends and relatives as well. Poetry reading opens doors to the heart and the mind. Poetry is a deep expression of emotion and the understanding of life as well as death. Don’t hesitate to broaden your own poetic horizons by experiencing your own poetry and that of others. Try some of the outlets and inlets listed above.
