Welcome to beszeljukmac.com
Web Hosting - How To Select A Web Host
As with many purchases, our first impulse when selecting a web hosting company is to go with the cheapest. Hey, they're all alike, why pay more? Au contraire.
There are a number of objective criteria that separates one web hosting company from another and money is only one of them. And not the most important one. Selecting a company based on price alone is equivalent to selecting an auto mechanic on price alone. Sure, he may maintain or fix your car cheaper. But will the car spend all the time in the shop and none on the road?
The first consideration is 'horsepower'. Do they have the capacity to carry your load and deliver decent performance? Most hosting companies will advertise that they have huge bandwidth and hundreds of servers. They're usually telling the truth.
But there's a difference between existing capacity and usable capacity. If they also have thousands of sites with millions of visitors per day the available or free capacity will be much lower. A big pickup truck may be able to tow 5,000 lbs. But not if it's already carrying 4,999.
Be sure to ask about available capacity, and have the prospective company back it up with reliable numbers. If you can't interpret the information they provide, find someone to help you do so.
Next, and a very close second, is reliability. A lot of power is worthless if it's cut often. Outages are a normal part of business. Even Google and Microsoft go down from time to time. The difference is, it happens rarely and they have failover plans. That means, if their site/system does go down it's either up again in a flash, or you never see the outage because a backup system kicks in automatically and seamlessly.
Be sure to grill the company closely about their up time. They'll often tout 99.6%, or some such figure. But, like the on-time figures of the airlines, those numbers can be shaded by adjusting the definition of 'up time'. What matters to you is whether your visitors will be able to reach your site at any time of the day or night they might want to.
Find out what systems, both technical and human, they have in place to deal with failures of all sorts. Servers can go down, networks can fail, hard disks can become defective and lose data even when the other components continue to work fine. The result is YOUR site is unavailable, which is all that matters to you. The web hosting company should be able to deal with all of that and have you up again very quickly.
Last, but not least, is security. With the continuing prevalence of viruses and spam, you need to know that the web hosting company you select has an array of methods for dealing with them. That means a good technical plan and staff who are knowledgeable in dealing with those issues. The old saying: 'an ounce of prevention is worth a pound of cure' is more true here than anywhere else.
All these issues are central to finding a web hosting company that can deliver the services you need. After those criteria are satisfied by a number of candidates, then you can start narrowing them down by price.
Assistance on Filling Out those Online Forms for the Free Stuff So, you’ve found a great freebie online, or a free trial of some service you have been wondering about, but the form you have to fill out has left you scratching your head. Sometimes the paperwork involved in getting some free stuff can seem a bit like applying for a mortgage or filling out your life insurance policy, and in fact, many people decide the freebie isn’t worth it after all when they’re facing down an intimidating form to fill out. The good news is that you don’t have to miss out on the free stuff just because the form leaves you a little perplexed. This guide will walk you through filling out these online applications, even if this is your first trip around the Internet. Once you get the hang of things, you’ll be filling out these forms in no time at all. First things first: once you have the form open on the screen in front of you, you have to move your mouse so that the cursor sits in the very first empty space on the form, and then click the mouse once. Some forms will automatically place your cursor there when you open them, but if you are not sure, moving the mouse there and clicking won’t hurt anything at all. All you have to do now is start typing, filling in the information they ask for in that field. Filling out the form the entire form is merely a repetition of this process. Of course, you have to be able to move between the fields easily so you can fill in the rest of the form. On some online forms, the cursor will move automatically when you have finished filling in a field, which makes life easy on you, but others do not. To manually move between fields, all you have to do is either hit the “tab” key on your keyboard or use your mouse to move the cursor to the next field, just like you did to start typing in the first field. Hitting “enter” may seem like a natural thing to do, and while it can work on some forms, other forms will submit themselves when you hit enter, meaning you will have submitted a blank form. It is best to stick to “tab” or your mouse to be on the safe side. This technique should allow you to navigate a freebie form fairly easily. There are a few other things you may see on a form that you have to know how to handle. You may be asked to “check” a box or indicate in a little circle (called a radio button) that you accept the company’s privacy policy or some other thing. To do this, all you have to do is move your cursor over the box or circle and click – the check or the dot will then appear. This can also be handy when forms ask for a billing address and a shipping address - if they are the same, you can tick a box stating so and avoid having to type the same thing twice. If a form has several pages, be careful to save your changes for every page as you move along. Usually there will be a button to click at the bottom of the page that allows you to save the work you have done. Especially long forms usually have some kind of side navigation that lets you skip around from section to section instead of moving through the form systematically – this can be helpful if you need to find some info for one section, but want to take care of all of the other work first. Most forms are reasonably user friendly and contain info to walk you through the process. If you get stuck, look for a help icon on the page – this info should clear up any questions you may have. International Software Copyright International Software Agreement is a Matter of National Security Is there one governing law concerning international software copyright? According to agreements by the World Trade Organization (WTO) and the Trade-Related Aspects of Intellectual Property Rights (TRIP) any software written has an automatic copyright. This is a pretty conclusive consensus as far as an international copyright goes. The short answer would have been yes, but this was so much more informative. An international software copyright should not however be confused with a patent. Copyrights provide creators with the ability to prevent others from directly copying the code involved. A patent can actually limit the use of the software. Because of this, I'm sure you'll understand that patents are a hotly debated topic when it comes to software. The biggest thing to know about international software copyright is that your code is essentially protected the moment you create it. This is, unless you have some kind of contract through your employer that all code created by your belongs to them (these cases have been known to happen and provide excellent incentives for employees to always read the fine print). The problem that many companies are running into when it comes to enforcing international software copyright is that computers are not permanent fixtures in a company. Computers are rather disposable hardware when it comes to keeping up with evolving technologies and software needs to be updated when new computers are purchased. Rather than purchasing new copies of software when the computers are replaced companies are notorious for reusing old copies of the software. They are also famous for replacing 10 computers with the software installed with 40 new computers and installing the 10 copies of the software on all 40 computers. This is not in keeping with international software copyright. This is stealing and you'd be surprised at some of the good upstanding companies that do this on a regular basis. There really are no major differences between traditional policies for American copyright and international software copyright which makes legal issues, troubles, and woes that much easier to deal with. By having a unified international front thee are ramifications and legal actions that can be taken around the world without going through a great deal of international red tape. If you think dealing with the American government is bad, you should see how much fun it is to deal with the American government and another government for a legal action. The agreement between nations for international software copyright is probably one of the soundest possible decisions that can be made as military secrets of all governments have some degree of software in order to keep them operating. While it isn't quite as simplistic as stealing a computer program to unlock the defense secrets of a nation, having access to certain source codes could be problematic in the absolute best-case scenario. Keeping secrets isn't the only thing that makes this agreement so valuable, it is however, one of the most vital. Perhaps one of the greatest things to come about as the result of the international agreement to protect and honor software copyright is the peace of mind that is available to software developers in America and other technologically advanced countries that their source code won't be allowed to be stolen and used against them at a later date by someone in a developing nation with cheap labor and other overhead costs that American corporations simply cannot compete with. This could be devastating to the economies of technological societies if it were allowed to happen and the agreement for an international software copyright prevents that from being allowed to occur. |
