Welcome to beszeljukmac.com
Web Hosting - Databases, What Are They and Do You Need One?
'Database' is one of the most commonly used terms that one encounters in web site design. Yet, what they really are and whether they're essential is often not clear to novices.
A database is a collection of organized data, stored in files that have a specific structure. It's that organization and structure that allows for easy and rapid storage and retrieval.
The need for a database generally only arises when you have a certain amount of information and that information needs to have some structure. If you have a half-dozen names and addresses to store, a database is usually overkill. If you have a blob of data with no relationships between any of the items in that blob, maintaining a database is usually more trouble than it's worth.
Maintain a database? Yes, like other complex systems a database, to be effective, needs to be designed properly at the outset then kept 'tuned' for good performance. The alternative is to gradually allow the database to become more and more disorganized. That leads to difficulty in use, poor speed of retrieval and more frequent failures.
With MySQL, Access or MS SQL Server, the three most common choices of database product for web sites today, setting up a database is relatively simple. Even those with limited technical skill can get one up and running just by following some simple instructions. But some thought should be given to how you want the information organized, and to maintaining the system during its lifetime.
Suppose you have a set of names, addresses, email addresses, products purchased, date purchased and amount. If you have only a few dozen records it matters very little how these pieces are arranged and related. A database usually isn't even warranted in this scenario. Once you have several thousand or more records, it matters a lot. Speed, the ease of expanding the set of attributes (like adding, say, product category), and other issues come into play.
Even those with little technical expertise, but a willingness to exert logical thought and invest some time, can build a very robust database. Think about how you would organize a set of data (called 'tables'). Should Name, Address, and Product be in the same table? Or should the personal information be stored in one table and any product information (product, price, ...) in another?
Some experimentation may be needed to get it right, but the choices have an impact on how easy the tables are to maintain. It also affects the speed with which programs can fetch old data and store the new.
Having a database also introduces new maintenance issues for the server administrator, since backups usually need to be done differently. Recovering a failed database is usually more complicated than simply re-copying files from yesterday. Ask your hosting company what tools and skills they have for dealing with any database system you consider.
It's true that introducing a database creates more complexity and the need for additional thought and administrative effort. At a certain level, professional expertise will be needed. But clearly the advantages outweigh the costs in many cases. Companies large and small eventually use databases to store and organize data. At some point, you may be fortunate enough to be one of them.
Copyright music expiration For Many Copyright Music Expiration is a Luxury for Worry If you copyright music, expiration isn't something you have to worry about, at least not in your lifetime. The music that you've written is copyrighted the moment you've put it onto paper or recorded it being played. The reason you don't have to worry about expiration is because the music is protected until 70 years after the death of the author. In the case of your music, that author would be you. This rule about copyright music expiration was first put into place so that the families and heirs of an author could still earn royalties even after his or her death. Ultimately this means that if you've taken the steps to copyright your music and have registered the copyright then your music will be protected throughout your lifetime until 70 years after you or the last surviving author (assuming a collaboration) are no longer living. Copyright music expiration is not something you should make a primary concern unless you are having issues of someone respecting and/or honoring your copyright at the moment. You should take comfort in the fact that as long as you are alive you are the only one who can assign your copyright to another person and as long as you haven't given up your ownership of the music it still belongs to you. This is different however if your copyrighted music was work made for hire. If that is the case then you cannot have ownership of the music, as it never legally belonged to you no matter what form it was in when it changed hands. Works made for hire have different copyright music expiration than those that were owned by the creator. With works made for hire, the copyrights are in effect for 95 years from the original publication date or for 120 years from the creation of the work whichever of the two is shorter. For most beginning musician’s copyright music expiration date isn't as important as getting that first gig or earning that first dollar as a result of the music he or she writes and/or plays. It's about art for many and about survival for others. The latter are quite often the ones that are taken advantage of. These are the authors who don't protect themselves as they should and end up failing to register their music because the idea of buying food seemed more pertinent to survival at the moment. This is often the case, particularly among street musicians and it's something that was becoming a growing problem immediately after hurricane Katrina devastated New Orleans taking with it many of the homes of starving musicians along with many pieces of music that will never become copyright music, expiration or not, those works are gone forever except in the mind of their creators. who could barely scrape together the money to pay $100 a month for a hovel they shared with 6 or 7 other people in order to keep expenses down and avoid living on the streets. The building not only of homes for those musicians displaced as a result of Katrina's devastation is wonderful but even more than that is the fact that there are organizations that are dedicated to creating a community for these musicians so that maybe many of the struggling artists won't be taken advantage of or have to face the decision to register their music in order to protect and copyright music expiration for their future heirs or to risk loosing their claim over the music they wrote in order to eat or pay the rent or buy groceries. Is Christian Publishing the Easy Road to the World of Writing Success? (Christian publishing) Any community with a special interest will pay for products that cater to that special interest. If that community is of significant size, you can bet that there will be products galore geared to them. There is money to be made where there is a need for a product. The Christian community is one such group that has a desire for a very specific product. They are interested in products that explain their faith and expand their knowledge of what is less understood within that faith. They also seek encouragement in what is already agreed upon. Because of all of these needs, there is certainly a market to be entered into within the Christian publishing network. The question is, since the group is exclusive, does that mean that there are too few writers for the consumers? Is it easier to get published when you’re not competing with the best of the secular authors? Those are difficult questions to answer with any certainty, but there are some topics to explore within that subject. Degree of Expertise In one genre of Christian publishing one qualification is essential. To write with expertise on subjects of faith, it is necessary to have the correct education. A seminary degree at the very least is required for convincing publications. The publishers do not accept authoritative writing from those without the proper education. When it comes to education, separate Christian denominations will expect degrees endorsed from those specific denominations. You may have expected that a Christian would need to write for the Christian community, but the requirements can be much more stringent. Just as a pastor or preacher must have the proper education to teach a congregation, a writer on subjects of theology or other topics from the Bible must also have the credentials to back up his claims. While it is not possible for every writer to obtain the correct degree for authoritative writing, there are other kinds of writing that will easier to achieve within Christian publishing. Experiential Knowledge A huge portion of Christian publishing is made up of personal stories. A Christian has unique experiences related to his faith. People who seek encouragement will buy books that relate to their own circumstances. A typical human problem is grief. If a Christian can effectively write about their grief from a perspective of faith then those writings will be helpful to other struggling Christians. Other important subjects include doubt, blessings and prayer. A lay Christian can back up their experiences and observations with scripture and therefore be much more relevant in their writing to the Christian community. If the writer’s material is not sufficient to fill a book, there are other outlets within Christian publishing for those who are able to inform and encourage fellow Christians. Magazines and church bulletins often publish poetry and short stories for the building up of believers. The Bottom Line Christian publishing may not be necessarily easier to do than secular publishing. If your heart is in the ministry to other Christians however, it may be the best field for you to attempt writing for. Christian publishing is not a ‘first step’ to enter into the publishing world. Most publishers are only looking for sincere and relevant publications. They will avoid writings done only for the money and will favor those with the honest goal of furthering the message of the Christian faith. Specific communities are looking for products geared to their lifestyles, but the best candidates for creating those products are those who have talent invested in that community. Entering into the Christian publishing world will be a similar task to entering into the scientific publishing world. It will take dedication and work. The writer will come out with a deeper understanding and faith of his own. |
