Welcome to beszeljukmac.com
Cruise for Free Stuff Anonymously with a Free Privacy Service
The World Wide Web is full of freebie offers, but many of these require you to give websites personal information and data. If you don't want your personal information floating around the World Wide Web (and who does want this?), there are some precautions you can take. Do you want to cruise for free stuff without having to worry about giving up your privacy? Here are a few privacy services that can help you cruise the web for freebies without having to worry about giving up any of your personal information.
Why Should You Protect Your Privacy?
Why should you even bother to use privacy services to cruise the web? There are many reasons why you would want to keep your personal data from being leaked into the World Wide Web. Every time that you are asked to provide personal information, you are at risk for infecting your computer with some kind of virus or spyware. In fact, it is estimated that the majority of all computer systems are infected by spyware. There are many programs that can actually track your keystrokes. This allows hackers and other cyber criminals to gain access to your passwords, bank account numbers and other private information. This puts you at high risk of computer identity theft. You can avoid having to enter personal information by using privacy programs to surf the web.
Surf Easy with Anonymizer.com
This is a program that allows you to surf the web anonymously. What does this program do? This program protects you by keeping your IP address secure. This means that online tracking software will be unable to track the sites you visit and keep a profile on your online activities. This program allows your connection to be redirected through their own secure servers, thus keeping your online identity hidden and protected. This program uses 128-bit Secure Sockets Layer technology. The program also provides protections against pharming, phishing and spyware websites that seek to invade your computer.
Keep Your Privacy with Enonymous
What is Enonymous.com, and what can it do to protect your privacy? Enonymous.com offers web surfers the ability to cruise confidently with its own host of free privacy software. This privacy software was created as a way to protect web surfers and consumers right to privacy. The program offers users with privacy policy statements and ratings. The software also helps users choose what kind of personal information they want to divulge before making web purchases. If you are concerned about giving away your name, phone number, email and other personal data, not to mention credit card and bank account numbers, then you will appreciate this software program.
For Fast, Free and Totally Private Email, Turn to Hushmail
Are you looking for fast, free and private email? If so, Hushmail.com is what you are looking for. This email uses industry standard algorithms that are optimized for the highest level of privacy, authenticity and security. This is one of the best of the free email services if you are concerned about protecting your privacy. All you need to do is to create your own passphrase. The program creates a transparent decryption and encryption system. It is also very user-friendly that allows for easy encryption and decryption of data, and for fast retrieval of a public/private key.
ZoneAlarm for the Best in Firewall Protection
If you are looking for the best in firewall protection, consider using ZoneAlarm for protecting your PC from invading viruses and spyware. This award-winning program helps shield your computer from incoming attackers, and helps banish already-present invaders. Surf the World Wide Web with confidence with the help of ZoneAlarm.
What to Think about While Choosing a Writing Desk (writing desk) Writing desks come in many shapes and forms. The technical definition is a piece of furniture with a surface for writing, with drawers and pigeonholes for writing materials and a portable case that when opened forms a surface on which to write. A writing desk could be as complex as that definition or as simple as a desk for writing. Basically a writing desk can be anything that you want it to be. You may not need to buy a writing desk. You may be perfectly comfortable with one you already have or working on the couch or at the kitchen table. This is fine. If it is a cohesive work environment for you that is fabulous, but some writers require a more formal, dedicated area just for them. By finding the perfect writing desk, you are on the way to the start of creative that work style atmosphere that they need. Before you begin your writing desk shopping venture you must first have two things picked out. The area in which your desk is going to go and the chair you are going to use. The location of the desk is important because it will be necessary to choose a size and style. The chair is important for comfort and maybe an important factor in determine the correct height of desk needed. Once these are figured out you shopping journey is ready to begin. While shopping for a writing desk the most important feature is comfort. You need to sit at the desk for most likely for hours at a time. Having a desk at the right height is imperative to this. With the writing surface being to high or to low will not only be uncomfortable but also will more that likely make it difficult for you to concentrate and write. Having a writing desk that is not the correct height is likely to cause neck and back strain. The function and the size of your writing desk are the next factors you need to consider before you purchase one. Do you need one with a little storage or a lot? Does it need to have an adjustable surface or can it just be flat? With all the choices available assessing what you need can help narrow down the ones that will work for you. How big of a space do you have for it? These are some simple considerations that are often forgotten while buying a writing desk. It would be terrible to fall in love with a desk and bring it home just to find out that it is not going to fit. The next important thing is style. When choosing the style of the writing desk you will want it to flow with the furniture already in your home. If your home is modern or contemporary you may want to choose one of the metal and glass desk designs or perhaps one with light wood tones and metal accents are right for you. Another great writing desk available is called the secretary. The secretary is wooden desk with drawers on the bottom and a fold down writing surface. They are usually compact in size but have ample storage and often offer shelving covered by glass doors on top. Plus having a fold down writing surface, it is easy to close up when you are done and hide you space altogether. Choosing the writing desk that is right for you may not seem that important. I mean how difficult could it be to choose a surface to write on, right? But making sure comfort, storage, and style fit into your lifestyle is an important decision. This is part of creating a suitable working environment for you to produce your work. Web Hosting - Email Issues When you build a web site, you often provide a means for users to communicate with you. One of the most common 'add-ons' to a web site is the addition of some kind of email access. Email is used to sign users up for newsletters, provide communication for administrative issues and a hundred other uses. But, as everyone sadly knows, email problems can occur. Virus infection is among the most common, though the situation is actually better today than in the past. Huge efforts, and some progress, has been made over the past 10 years to reduce the number and severity of virus attacks. Hackers haven't surrendered, far from it. But they're on the defensive like never before. Many of those viruses were (and are) spread through email, usually in the form of email attachments. That's the source of the now-common advice never to open an attachment from someone you don't know. Professionals will often extend that advice to suggest you never open an attachment that's unexpected, even if it's from someone you know. Well-meaning, but computer-challenged friends often accidentally forward virus infected emails. Spam has taken over the top spot for email annoyances. It's estimated by various different professional sources that 92-97% of all email sent today is spam. While the definition varies, spam is generally regarded as any unwanted commercial email sent by someone whom the recipient doesn't know or have a business relationship with. Spam clutters email inboxes, requires people to sift through to find valid messages, and often contains offensive messages in some form. But, it's a fact of life and isn't going away anytime soon. Even though laws are in place, thousands of spammers continue to risk fines or jail for the chance of making money from that small percentage who will open the unwanted email. Other forms of email problems are even more severe for many web site owners. When the mechanisms fail that they rely on to send and receive messages to and from their users, that's a problem. Dealing with those problems can range from sending an email or instant message to an administrator, to tracking down the right person to get your site removed from a blacklist. Email is the communications vehicle of choice for millions everyday. When the system burps, someone has to take time to do something about it. Often, that means relying on a person who is already overburdened with too many issues to resolve. So, besides pointing out some sad facts or complaining, what's the point? All of the above shows just one more area you should look at when selecting a web host or deciding whether to move to another. Just as with server or network administration, companies vary in their ability to deal with email-related issues. Some are responsive and super-competent. Others, are simply indifferent or worse. And many are in between. Email administration, like server maintenance or network management, is a professional specialty. Skill in one does not necessarily mean quality work in another. Finding a web hosting company and/or system that has few email problems, and solves them quickly when they occur, is an important task. Spend some time researching who provides superior support in email. You'll be happy you did. |
